21618 Discussions
Concept of CRC24 calcualtion for 64 bits
Does anyone knows concept of CRC calculation? (which is generated by ALTERA for Interlaken protocol core )
Kindly refer the document of advanced synthesis cookbook.
I don't know how are they doing XOR operation for incoming 64bits?
CRC24 calculation == DATA 64 bits (single cycle)
Kindly see the attached file for CRC calculation.
I understand you're asking about parallel calculation of the CRC. I've written this article (http://outputlogic.com/my-stuff/circuit-cellar-january-2010-crc.pdf)a while ago on the subject that you might find useful. Also, there is online tool (http://outputlogic.com/?page_id=321) to generate CRC for different polynomials and data widths.
Evgeni
Thanks for your reply. I went through that paper which u suggested but in that paper they have used matrix method.
Could you just explain the concept of Table 2? i.e Mout (next state CRC) as a function of Min(current state CRC) when N=0
In that table 2 matrix ,I'm not able understand how you are making Min[0] is 1 initially i.e. Min[0] row[0] = 1 0 0 0 0 (rest of rows I understand)
Mout = F(Nin=0,Min)
Nin = 0 Mout[4] Mout[3] Mout[2] Mout[1] Mout[0]
Min[0] 1 0 0 0 0
Mout = F(Nin=0,Min)
Min[0] 1 0 0 0 0
Thank you sir
Each row corresponds to Mout for different Min, from 0x01 to 0x10. So, for example, when Min=0x1 (first row), Mout bits are 10000. 2'nd row is Min = 0x2, etc.
The reason why it's Min[0], Min[1], etc, is that Min values are one-hot encoded.
Evgeni
