21592 Discussions
Configuration via Protocol (CvP) fail after loading the periphery image
JonGoh
May I know if this issue has been resolved in newer versions of the CvP driver? I am still facing CvP intermittent failing problems and was wondering whether there are other workarounds other than the need for a power recycle.
"Due to a CvP upstream driver issue, CvP may intermittently fail after successfully loading the periphery image into all Intel Agilex® devices with package code R31C / R31B.".
Here is the link where I found the article:
https://www.intel.com/content/www/us/en/support/programmable/articles/000089044.html
Jon
JohnT_Intel
Are you able to try with the increasing the timeout value?
JohnT_Intel
HI,
Thanks for confirming that updating the timeout value resolved the issue in our call discussion
thedentaku67
The issue has been fixed in Quartus 22.2.
freddy3366
Hey, I’m not sure if it’s fixed in the newer CvP driver versions, but the intermittent failures seem to still be a thing for some. If power recycling isn’t ideal, maybe reach out to Intel support—they might have alternative workarounds. Good luck!
