21605 Discussions
Configuring FPGA from HPS on SoCKit board
Hi everybody!
I'v managed to boot Linux from QSPI-flash on SoCKit board, but I can't configure FPGA from QSPI-flash. I'm trying to configure FPGA from preloader as shown in
GSRD v13.1- Programming FPGA from HPS.
I created 3 partitions for QSPI and wrote fpga.rbf file into /dev/mtd2, rebuilt preloader (after making changes in socfpga_common.h file) and flash it into /dev/mtd1. After powering the board I got
U-Boot SPL 2013.01.01 (Apr 10 2018 - 11:59:25)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 925 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 370000 KHz
RESET: COLD
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
FPGA : Programming FPGA
SF: Read data capture delay calibrated to 3 (0 - 7)
SF: Detected N25Q512 with page size 65536, total: 67108864
into the Linux console... I've tried MSEL="00000" and "01010", but without any success. Bootsel = "111" (boot from QSPI).
If I change the preloader to another one (without FPGA from QSPI configuring support) Linux normally starts from QSPI...
Any help will be appreciated.
