I am developing a board around a Stratix 10 that will be conformal coated. Are there any limitations or masking requirements I should be mindful of with the Stratix 10? There is what appears to be a vent on the case which I am wary of coating over.
You may need to ensure the vents and heat dissipation features are not obstructed. Avoid coating areas that may expand or contract during operation, and Stratix 10 is using advanced packaging, so coating must not interfere with interconnects or exposed die area.
regards
Farabi
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
