21602 Discussions
Connection refused error when starting P4 studio runtime environment in Tofino hardware
Frank_Chenxingyu_Zha
I am using a Wedge100BF-32X programmable switch and trying to setup Intel P4 studio SDE in this switch to run P4 programs. When I try to run a P4 example program tna_resubmit with P4 studio SDE using the following command,
root@localhost:~/bf-sde-9.9.0# ./run_switchd.sh --arch tofino -p tna_resubmit
I am getting the following error:
connect failed. Error: Connection refused
The full output from the command is here.
Environment:
P4 studio SDE version: 9.9.0
uname  -r: 4.14.151-OpenNetworkLinux
cat /etc/onl/platform: x86-64-accton-wedge100bf-32x-r0
ls /dev/bf0: /dev/bf0
lsmod:
Module                  Size  Used by
bf_kdrv                24576  0
pmbus                  16384  0
pmbus_core             28672  1 pmbus
x86_pkg_temp_thermal    16384  0
gpio_ich               16384  0
optoe                  20480  0
A user on Github suggested reloading kernel driver and checking if /dev/bf0 exists. I did them both, but the issue remains. Any help would be appreciated.
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
KennyTan_Altera
This seems to be Tofino issue but not FPGA issue, do you mind to look for the correct place to raise the question?
You may take a look into https://community.intel.com/
Kenny Tan
KennyTan_Altera
closing the case as there are no feedback on this.
