21602 Discussions
CoreClk of alt4gxb
I want to use 10 alt4gxb transceivers for a 100 gig ethernet link.
As described in an570.pdf from the altera website I connected the rx_clkout(0) port to every rx_coreclk port.
When fitting, I'm always getting the same error message:
Error: Input port CORECLK of GXB Receiver channel PCS "GX10ch:GX10ch_sec|GX10ch_alt4gxb:GX10ch_alt4gxb_component|receive_pcs1" must be fed by output port CLOCK_OUT of GXB Receiver channel PCS "GX10ch:GX10ch_sec|GX10ch_alt4gxb:GX10ch_alt4gxb_component|receive_pcs1" because the GXB receiver is not rate-match FIFO enabled or receiver is operating at a dissimilar data rate to the transmitters or receiver can be dynamically reconfigured.
[edit] I get this message for every receive_pcs (1 to 9) [/edit]
I've tried almost every possible combination with the instance assignment "GXB_0PPM_CORE_CLOCK" but none seems to work.
Does anyone have an idea?
Cheers
solution:
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from (tx/rx_clkout[0]*) -to DataInxDI/DataOutxDO[0]**
*tx_clkout of the GXB, which is connected to the other tx_coreclk
** the actual input/output ports of the high speed serial data of the top entity. Every port has to be assigned.
In my case:
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[0]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[1]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[2]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[3]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[4]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[5]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[6]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[7]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[8]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|tx_clkout[0]" -to SecGtTxSerDataxDO[9]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[0]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[1]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[2]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[3]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[4]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[5]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[6]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[7]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[8]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_sec|rx_clkout[0]" -to SecGtRxSerDataxDI[9]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[0]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[1]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[2]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[3]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[4]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[5]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[6]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[7]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[8]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|tx_clkout[0]" -to UsrGtTxSerDataxDO[9]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[0]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[1]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[2]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[3]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[4]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[5]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[6]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[7]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[8]
set_instance_assignment -name GXB_0PPM_CORE_CLOCK ON -from "GX10ch:GX10ch_usr|rx_clkout[0]" -to UsrGtRxSerDataxDI[9]
