21615 Discussions
Correct use of reset input of a FF. VHDL
In my design I will process an image.
In part of my hardware I need to RESET some FLIP FLOPS when FVAL(frame valid) arrives.
Is bad if I use the signal FVAL directly connected to the reset input of the Flip FLop?
Please look the attached file.
If I give reset directly with the FVAL, it will use less resources, but I do not know if it is bad.
Or the reset must be always connected to the global reset.
Sorry for the dummy question.
It's safer to use a synchronous reset instead of an asynchronous one like you are proposing. if FVAL signal is glitch free, it could work, however, i guess FVAL is synchronous to master clock and is preferable adding a synchronous reset signal to your hardware.
Selecting between async or sync reset is not a trivial issue.
You need async reset at power-up, or when you have no clock yet, or when you can't afford the pipeline cycle (sync reset would reset the flip-flop in the next cycle, async would reset on "this" one).
In either case you should synchronize the reset signal to the flip-flop clock.
