Counter in VHDL
I want to design a 16 bit counter with 1uSec resulution.
I have only 40MHz clock and can't use neither PLL or frequency divider.
I can use only the 40MHz global clock.
Can somebody recommend for VHDL design for 16 bit counter with resulution adjustment?
THX
GUY.
run another counter at 40MHz. When it reaches a given number generate an enable that increases the main 16 bit counter.
Thank you!
I want to implement it in minimum hardware. You think this is the most minimized option?
Guy.
Possibly.
If you come up with other ideas, give them a go too and look at resource usages.
Thank you .
You will need 16+6 flops and some logic at the minimum.
