Hi every body
Here i am again Now my PLD epm1270 prototype is running, tested and it looks doing a fine job, next problem is: How can I allow my fellows to unload via JTAG the POF file to the target without distibute all Quartus II software. In other words, does anybody know about tool (lightweight) installable on an old an busy P.C. able to do that ? Possibly via serial or parallel port. Thanks a lot ALFredoLink Copied
You can install the standalone Quartus II programmer without installing all of the Quartus II software. Then you just need a USB-Blaster or a Byte-Blaster.
https://www.altera.com/support/software/download/programming/quartus2/dnl-quartus2_programmer.jsp Jake- Mark as New
Thank you jake, for your very useful reply
