I'm trying to create a pipeline register for the IFETCH stage on a simple processor and I've hit a roadblock. The specific question I have is on how to pipeline the 32-bit instruction. I have pipelined the PC+4 signal, but I don't know how to do it with the Instruction coming out of the "Instruction memory". In "PORT MAP", q_a => Instruction, but I don't know what q_a is. The PC is 10 bits and goes into the "Instruction Memory" stage and obtains a 32 bit instruction: 5 is for $1, 5 for $2, 5 for opcode?, some(?) goes to control bit and some goes to the sign extend. The question is, how do I get the that 32 bit Instruction so I can store it in a register to pipeline it. I've attached the code in the bottom. I tried to create a new register D_Instruction (31 DOWNTO 0) and then set it to the Instruction at the clock cycle then, set the q_a to D_Instruction. Thanks for your help! -- Ifetch module (provides the PC and instruction --memory for the MIPS computer) LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; LIBRARY altera_mf; USE altera_mf.altera_mf_components.all; ENTITY Ifetch IS PORT( SIGNAL Instruction : OUT STD_LOGIC_VECTOR( 31 DOWNTO 0 ); SIGNAL PC_plus_4_out : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0 ); SIGNAL Add_result : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 ); SIGNAL Branch : IN STD_LOGIC; SIGNAL Zero : IN STD_LOGIC; SIGNAL PC_out : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0 ); SIGNAL clock, reset : IN STD_LOGIC); END Ifetch; ARCHITECTURE behavior OF Ifetch IS SIGNAL PC, PC_plus_4 : STD_LOGIC_VECTOR( 9 DOWNTO 0 ); SIGNAL next_PC, Mem_Addr : STD_LOGIC_VECTOR( 7 DOWNTO 0 ); -- Pipeline register SIGNAL D_PC_plus_4 : STD_LOGIC_VECTOR( 9 DOWNTO 0 ); SIGNAL D_Instruction : STD_LOGIC_VECTOR( 31 DOWNTO 0 ); BEGIN --ROM for Instruction Memory inst_memory: altsyncram GENERIC MAP ( operation_mode => "ROM", width_a => 32, widthad_a => 8, lpm_type => "altsyncram", outdata_reg_a => "UNREGISTERED", init_file => "program.mif", intended_device_family => "Cyclone" ) PORT MAP ( clock0 => clock, address_a => Mem_Addr, q_a => D_Instruction ); -- Instructions always start on word address - not byte PC(1 DOWNTO 0) <= "00"; -- copy output signals - allows read inside module PC_out <= PC; PC_plus_4_out <= D_PC_plus_4; -- Pipeline register D_PC_plus_4 <= PC_plus_4; -- send address to inst. memory address register Mem_Addr <= Next_PC; -- Adder to increment PC by 4 PC_plus_4( 9 DOWNTO 2 ) <= PC( 9 DOWNTO 2 ) + 1; PC_plus_4( 1 DOWNTO 0 ) <= "00"; -- Mux to select Branch Address or PC + 4 Next_PC <= X"00" WHEN Reset = '1' ELSE Add_result WHEN ( ( Branch = '1' ) AND ( Zero = '1' ) ) ELSE PC_plus_4( 9 DOWNTO 2 ); PROCESS BEGIN WAIT UNTIL ( clock'EVENT ) AND ( clock = '1' ); IF reset = '1' THEN PC( 9 DOWNTO 2) <= "00000000" ; ELSE PC( 9 DOWNTO 2 ) <= next_PC; END IF; END PROCESS; -- Processes for pipeline register : PC+4 PROCESS BEGIN WAIT UNTIL ( clock'EVENT ) AND ( clock = '1' ); IF reset = '1' THEN D_PC_plus_4( 9 DOWNTO 0) <= "0000000000"; ELSE D_PC_plus_4( 9 DOWNTO 0) <= PC_plus_4; END IF; END PROCESS; -- Processes for pipeline register : Instruction --PROCESS --BEGIN --WAIT UNTIL ( clock'EVENT ) AND ( clock = '1' ); --IF reset = '1' THEN -- D_Instruction( 31 DOWNTO 0) <= "00000000000000000000000000000000000"; --ELSE -- D_Instruction( 31 DOWNTO 0) <= Insruction; --END IF; --END PROCESS; END behavior;Link Copied
