21602 Discussions
Critical Warning: Timing requirements were not met
Hi
I got the following critical warning when I tried to compile my code.
Critical Warning: Timing requirements for slow timing model timing analysis were not met. See Report window for details.
Clock Hold: 'pll_80_to_64:Inst_PLL|altpll:altpll_component|pll_80_to_64_altpll:auto_generated|wire_pll1_clk[0]'
Is it compulsory to get rid of this critical warning? If so, what should I do to get rid of it?
--- Quote Start ---
Hi
--- Quote End ---
can explain the problem more detailed (.e.g. list a path ...)
Kind regards
GPK
