21602 Discussions
Cyc V-SOC Dev-Board LVDS with different clocks via HSMC-Connector
As I do not know whether my problem only applies to the Cyclone V SOC or not, I decided to post my problem here:
My setting consists of the Cyclone V SOC dev kit I mentioned already in the title (with hardware SERDES, if that matters) and a Cyclone IV board (with SERDES in logic cells).
My goal is to input parallel data with 80MHz and a width of 48bit into the Cyclone IV, send it via SERDES (6 channels, deserialization factor of 8) to the Cyclone V and reconstruct the 48bit-vector (and the other way round).
Therefore I have: 1 SERDES-TX and 1 SERDES-RX per side (I used the altlvds megafunctions), each SERDES-TX clocks (or at least: should clock) the SERDES-RX of the opposite side. The serial data (and the resulting two clocks) shall be transmitted via LVDS over the HSMC connector.
There, I am not absolutely sure which bank to use, but if I am right, the need of 6 channels and LVDS limits me to HSMA_TX_D and HSMA_RX_D?
I hope this explains my configuration which leads to following error:
As Quartus tries to create a fractional PLL for both, tx and rx, and wants to place them as near as possible to the input (respectively output) pin, it cannot complete this task and gives the following error message:
Error (175020): Illegal constraint of fractional PLL to the region (0, 73) to (0, 81): no valid locations in region Info (175028): The fractional PLL name: serdes_rx:serdes_rx1|altlvds_rx:ALTLVDS_RX_component|serdes_rx_lvds_rx:auto_generated|pll_sclk~FRACTIONAL_PLL Info (175013): The fractional PLL is constrained to the region (0, 73) to (0, 80) due to related logic Info (175014): Region must be within (0, 73) to (0, 80) due to the signal(s) routed from the fractional PLL to PLL output counter serdes_rx:serdes_rx1|altlvds_rx:ALTLVDS_RX_component|serdes_rx_lvds_rx:auto_generated|pll_fclk~PLL_OUTPUT_COUNTER Info (175014): Region must be within (0, 73) to (0, 81) due to the signal(s) routed from the PLL output counter to PLL LVDS output serdes_rx:serdes_rx1|altlvds_rx:ALTLVDS_RX_component|serdes_rx_lvds_rx:auto_generated|pll_ena~PLL_LVDS_OUTPUT Info (175014): Region must be within (0, 74) to (0, 75) due to the signal(s) routed from the PLL LVDS output to pin HSMA_RX_D Info (175015): The I/O pad is constrained to the location PIN_H14 due to: User Location Constraints (PIN_H14) Error (11238): Node is not compatible with other nodes placed at the same location either because there are too few available fractional PLL locations, or the nodes have different inputs, parameters, or both. Error (11239): Could not merge with previously placed fractional PLLs at location FRACTIONALPLL_X0_Y74_N0 Info (11237): Already placed at this location: fractional PLL serdes_tx:serdes_tx1|altlvds_tx:ALTLVDS_TX_component|serdes_tx_lvds_tx:auto_generated|pll_fclk~FRACTIONAL_PLL Info (175013): The fractional PLL is constrained to the region (0, 31) to (0, 81) due to related logic Info (175014): Region must be within (0, 31) to (0, 81) due to the signal(s) routed from pin clk_in to the fractional PLL Info (175013): The pin is constrained to the region (7, 81) to (32, 81) due to related logic Info (175034): Assignment 1: Region must be in (7, 81) to (40, 81) due to the constraint on I/O pad clk_in, which is a part of pin clk_in Info (175015): The I/O pad is constrained to the location PIN_K14 due to: User Location Constraints (PIN_K14) Info (175034): Assignment 2: Region must be in (7, 81) to (32, 81) due to the signal(s) routed from the pin to fractional PLL serdes_tx:serdes_tx1|altlvds_tx:ALTLVDS_TX_component|serdes_tx_lvds_tx:auto_generated|pll_fclk~FRACTIONAL_PLL Info (175013): The fractional PLL is constrained to the region (0, 73) to (0, 80) due to related logic Info (175034): Assignment 2: Region must be in (0, 73) to (0, 80) due to the signal(s) routed from the fractional PLL to PLL output counter serdes_tx:serdes_tx1|altlvds_tx:ALTLVDS_TX_component|serdes_tx_lvds_tx:auto_generated|pll_fclk~PLL_OUTPUT_COUNTER Info (175013): The PLL output counter is constrained to the region (0, 73) to (0, 81) due to related logic Error (12289): An error occurred while applying the periphery constraints. Review the offending constraints and rerun the Fitter.
What can I do to solve this? Is the idea to use the outclock of each tx block to feed the inclock of the corresponding rx block not the way things should be done? Replacing clk_in by a altclkctrl megafunction did not solve the problem either.
Any help is appreciated, thanks
herrhannes
Does nobody know an answer or did I forget to mention something important?
Using an external PLL and constraining it manually to another location does also not solve the problem as these assignments are ignored by the fitter.
Maybe this page will help for you
http://www.altera.co.uk/support/kdb/solutions/rd03312013_521.html
I had the same problem, and the above page pointed me in the right direction. The QSF fix wasn't applicable for me, what I did was
  1. Go into the MegaWizard
  2. Edit the SERDES
  3. Go to Transmitter settings
  4. Enable "Use 'tx_coreclock' output port
  5. Change from "Dual Regional" to "Auto"
  6. Disable "Use 'tx_coreclock' output port
  7. Finish
Even though the box isn't highlighted, if you have it set to Dual Regional, it will fail to build.
