21615 Discussions
Cyclone 10 LP Clock input and data in different banks
I am new to Cyclone 10 LP device and plan to use 10CL016YU484C6G device in my design. I have a question related to clock pin and data pin connection for a source synchronous data bus.
A) In a source synchronous interface, is it required to connect data and clock input signals to the same bank (being grouped together in same bank)?
In other words, can a clock input be connected to CLK dedicated Input pin present in Bank-1 and data bus [15:0] signals be connected to any different bank (say Bank-2 to 8)?
Note: CLK frequency of the bus is 80MHz for the source synchronous interface.
Shareef
That sounds absolutely fine. I don't anticipate any problems with that. Constrain the interface appropriately and you shouldn't have any problems. Worst case (which I really don't envisage) you may need to instantiate a PLL - you may wish to do this anyway - to generate a phase adjusted local clock but I really don't anticipate the need for that.
Cheers,
Alex
