Programmable Devices
21603 讨论
Cyclone II and DDR pins
名誉分销商 II
1,344 次查看
Hi
In Cyclone II ep2c5 pinouts document:
http://www.altera.com/literature/dp/cyclone2/ep2c5.pdf
Some pins have additional discription: DQxxx DQSxx DMxx.
Why this DDR signals are assign to this pins? Is that requisite assignment or only recommended? If recommended then why?
PGW
0 项奖励
3 回复数
名誉分销商 II
636 次查看
I found information that DQS signals are assign to this pins because this pins are routed directly to the clock control block and global clock bus.
But I still don't know why DQx (data) and DM (data mask) signals are assign in this way.
This assignment is not comfortable for me but I don't know whether I can change it.
Any suggestion will be appreciate.
PGW
0 项奖励
名誉分销商 II
636 次查看
You need to assign DQS/DQ lines to special S/Q pins because the FPGA logic (usually the ALTMEMPHY) needs to adjust the clock phase at the input buffers in order to capture the data correctly. Only S and Q pins have this capability.
DM lines, which are outputs (and all the other DDR lines for this matter), can be assigned to any pins as far as I am aware.
0 项奖励
名誉分销商 II
636 次查看
--- Quote Start ---
--- Quote End ---
Thanks for response.
0 项奖励
回复
