21599 Discussions
Cyclone III 3.3V LVTTL
In my design I have a 3.3V LVTTL interface with a silab PLL which operates at 2.5V LVCMOS.
The Voh value of the lvcmos is 2.1V and the Vih of the 3.3V LVTTL is 1.7V.
Now, since the noise margin is 0.4V I guess that no problem will occur.
Should I be careful of anything else?
Is there any problem with connecting these two interfaces directly?
(direction of 3.3V to 2.5V is lowered with voltage divider).
I thank you all,
Boris.
Any opinions?
Looks O.K. in my opinion. I would do the same. You should check, that no reflections are present, causing possible double clocking.
