21602 Discussions
Cyclone III Configuration
I have developed a custom board using Cyclone III (EP3C16E144C8) FPGA. I am using JTAG for programming and debugging purpose.
I have attached the schematics for the configuration pins.
The problem I am facing currently is that while emulating the singals on Signal TAP II file, I find Reset pin to be always high. I checked the signal using a multimeter and it was low.
I am still unable to understand why FPGA is considering the input of reset pin High.
Please notify me in case if I have any wrong configuration
http://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf
Page#171
Cyclone III Device Family Configuration Schemes
See if MSEL0,1,2 is correct for configuration mode you want.
The Reset pin should be just weak pull-high right?
Yes, I have grounded all three MSEL[0..3] pins for JTAG configuration.
--- Quote Start ---
(6) Do not leave the MSEL pins floating. Connect them to VCCA or GND. These pins support the non-JTAG configuration scheme used in production.
Altera recommends connecting the MSEL pins to GND if your device is only using the JTAG configuration.
--- Quote End ---
although I have also interfaced a EPCS4 in case I need to use Active serial configuration in future. (please refer to schematics attached)
can the presence of EPCS4 hardware be an issue ?
gotcha .. i ve to ground the pin instead of leaving it floating
i did it and issue was solved
thanks :D
