I have a question about the configuration of a Cyclone III with a EPCS16 in AS mode.
I have 8 prototype boards for development. JTAG program debugs OK. The POR configuration fails on 2 boards and intermittent on another 2. The solution is to place a 22pF cap on the DCLK at the EPCS device (I discovered this while using my scope probe). I am using Standard Speed AS. The EPCS is at 3V3, the MSEL pins are at 2V5. It is an 8-layer board with ground and power plane, but could this be poor routing / layout problem? The trace is 30-40 mm max. Are there any obvious things to look out for / have others had similar? Regards KonradLink Copied
I am seeing this problem now. Anyone else see this. My concern is that the ALTERA documentation says a maximum of 15pf on the DCLK pin, what can this really be?
