21594 Discussions
Cyclone III FPGA Starter Kit
Hello
I installed "Cyclone III Starter Kit" and played with the initially stored program (in which LEDs blink) using Board Test System.
But now I am wondering where I can get the project file(qpf) of this initially stored program.
I thought the project file named "cycloneIII_3c25_start_niosII_standard.qpf" is it but when I compiled the file I faced an error telling me "Error (12006): Node instance "comb_4" instantiates undefined entity "cycloneIII_3c25_start_niosII_standard_sopc."
So the question is
Can I see the preloaded program of Cyclone III Starter Kit?
and if "cycloneIII_3c25_start_niosII_standard.qpf" is the one I should look for, can you tell me how I can compile it?
Probably you need to rebuild the sopc system, in order to generate the requested entity.
You should have in your standard project a *.sopc or *.qsys file.
Launch Qsys and open this file, then generate the system. This should create the missing files.
Dear Cris72
Thanks for your reply.
I just tried the way you told me and could compile the "cycloneIII_3c25_start_niosII_standard."
I appreciate your help!!
--- Quote Start ---
--- Quote End ---
Hello Yhatagishi,
You use the same kit as me. You reached the same milestone as me. I could compile and execute this "cycloneIII_3c25_start_niosII_standard" on my cyclone III starter kit.
All 4 leds come turned on.
But what does it make? I can push any button ; nothing changes. Do I need some extra hardware beyond the cyclone III started kit? Do I need some Nios II Embedded Evaluation Kit?
Anyway, where to find more tutorials about this cyclone III starter kit?
Tutorials or project files for education purposes. Self-speaking project files.
There is no my_second_fpga my_third_fpga my_fourth_fpga, is there??
Is there some file server somewhere on internet where to download project file. Easily understandable.
Tutorials involving the fpga + the buttons + the leds + the memories on the board.
Tutorials involving floating point and fixed point arithmetic operations.
Understandable tutorials.
Tutorials executable by this Cyclone II starter kit.
Tutorials understandable by a beginner.
Thank you in advance.
Jean-Michel.
Hello, Jean-Michel
Sorry for late reply. It had been winter break.
--- Quote Start ---
--- Quote End ---
Is "Board Test System" installed under the folder named "Cyclone III EP3C25 Starter Kit v12.0.0" ?
If not, follow the "User Guide" (there should be an instruction of installing "Cyclone III EP3C25 Starter Kit v12.0.0").
--- Quote Start ---
--- Quote End ---
I think there is no additional "my_****_fpga" programs nor tutorials about the kit.
However, it is useful to refer to free online trainings which are available on the Altera's website.
--- Quote Start ---
--- Quote End ---
I think Altera is quite unfriendly to beginners...
Good luck with your kit.
Hope my reply would help.
Yukihiro
