21602 Discussions
Cyclone III pin assignment
I want to build a custom board based on CYCLONEIII. In my system i have a parallel flash (config. of the FPGA) & DDR 167MHz clk & also some differential SSTL/HSTL_18,15 , and also some 3.3V devices which will talk to the FPGA.
Now i am running short of banks as i have to support various logic families.
I have some doubts regarding assigning Vref voltages to various banks,
  1. In the pin out excel sheet of CYCLONEIII they have mentioned the dedicated cinfiguration pins, which i cannot change. Also the address & few data pins for the Config Flash in AP mode are given as 'Optional/Dual-Purpose Configuration Pins', so does this mean that I can uses these pins for both flash interfacing as well as data & address pins for ddr. (ie during config they will be used for FLASH & after config. as DDR pins)
  2. In the pinout excel sheet they have given specific pins for DDR interfacing (DQ, DQS, DM pins), do i have to use these specified pins only for DDR interfacing or I can use any other IO pins?
AP related dual purpose pins can be used for user I/O, if you don't intend to access the flash in user configuration. In this case, the flash could only be programmed by loading a dedicated flash loader configuration. Also the user logic connected to the pins must no disturb flash operation, e.g. not drive out unintentionally.
The I/O standard used for DDR RAM address and data lines is obviously incompatible with a flash interface. I can hardly imagine, how they should share a pin.
The requirements for DDR RAM I/O are discussed in various documents, e.g. the controller user guide and Cyclone III specific application notes. As a general answer: yes you have to keep a specific pin selection strictly, at least for DQ and DQS pins.
You also should be aware of the distance rules when mixing voltage referenced and other I/O standards in a bank. At best, assemble a test design including the RAM controller, e.g. together with the Altera provided test driver, all pin definitions and typically some dummy logic to stimulate the pins.
Hi.. Can any1 send me the standard pin assignments of NiOS II Eval board(Cyclone III EP3C25)?
You can copy the pin assignments from the example designs, e.g. from cycloneIII_3c25_start_niosII_standard.qsf.
