21611 Discussions
Cyclone III pin assignment?????????
I am a beginner in this field of FPGA,
and I have to make a video converter (composite -> VGA) using CYCLONE III.
I finished the development of all blocks in verilog and I still have the implementation of my code in that famous FPGA.
my problem is the assignment of pins.
I can not find the table showing the pin assignments of such audio or video codec decoder (for example)....
can somebody help me please?
--- Quote Start ---
--- Quote End ---
the required pin assignments depends on your board. E.g. you have to look which FPGA pins are connected to VGA connector.
Kind regards
GPK
--- Quote Start ---
GPK
--- Quote End ---
... then you open the Assignments->Pins Quartus menu and you'll find a table/fpga-layout where you can constrain each internal signal to connect to the proper pin.
Cris
Cyclone® III FPGA base board
+ touch-panel LCD daughter card
In this case, u can use the user pins as output pins. See the list of user pins available and assign your outputs to those pins.
