21602 Discussions
Cyclone III using 3.3V power supply
Hi there,
my embedded system is based on a Cyclone III powered using an external 3.3V power supply. I already found the solution used in DK-DEV-3C120N to drive 1.2V (core) and 2.5V (PLLs) using a 3.3V supply.
But I'm still locking for a smart solution (i.e., low price and small area) to supply a smaller device (i.e., EP3C40F484C6N) with a lower power consumption efficiently.
Can anyone help me with that?
Thanks in advance
Modellpilot
The best soultion depends mainly on the power demand of your application, particularily for core supply. It may range from a few 10 mA to several A. Linear voltage regulator solution may be suitable up to at least some 100 mA, it's clearly the cheapest solution.
To give a ballpark figure, we are talking about 300..500 mA. Do you have any suggestions regarding the voltage regulator (maybe including a schematic)?
For 500 mA from 3.3V, a LT1963A in DD-Pack could be used, a synchronous switcher would give lower power dissipation. All major manufacturers have suitable devices, I have used TI TPS62040 previously, see appended circuit.
i use en5312(enpirion) for core voltage(ep3c25/ep3c16).
