Hi all,
I'm interested in using the Cylcone V for a project involving an image sensor with 4 DDR LVDS channels each 12 bit encoded. I noticed, in the LVDS RX IP, 10 bit word lengths is the maximum and the input has to be connected to an LVDS pin on the FPGA. Is there anyway of chaining the SERDES or use another method to achieve 12 bit deserialisation? Thanks BoscoeLink Copied
I'm using x6 SERDES and combining 2x6Bit to 12 Bit output at half slowclock rate. 12-Bit ADC with LVDS output at 480 MHz LVDS/40 MHz output data rate.
Used code as is
LVDSCLK : altera_pll
GENERIC MAP
operation_mode => "lvds",
reference_clock_frequency => "40.0 MHz",
number_of_clocks => 4,
output_clock_frequency0 => "480.0 MHz",
phase_shift0 => "1041 ps",
duty_cycle0 => 50,
output_clock_frequency1 => "80.0 MHz",
phase_shift1 => "-5208 ps",
duty_cycle1 => 50,
output_clock_frequency2 => "80.0 MHz",
phase_shift2 => "4167 ps",
duty_cycle2 => 17,
output_clock_frequency3 => "40.0 MHz",
phase_shift3 => "7292 ps",
duty_cycle3 => 50
PORT MAP
rst => reset,
refclk => AD9222_FCO,
outclk(0) => fastclock, -- 180° 1041 ps
outclk(1) => slowclock, -- 210° -5208 ps
outclk(2) => enaclock, -- 120° 4167 ps
outclk(3) => outclock,
locked => rx_locked
chan:
FOR I IN 0 TO N_AD_CHAN - 1 GENERATE
ALTLVDS_RX_component : ALTLVDS_RX
GENERIC MAP (
buffer_implementation => "RAM",
cds_mode => "UNUSED",
common_rx_tx_pll => "ON",
data_align_rollover => 4,
data_rate => "480.0 Mbps",
deserialization_factor => 6,
dpa_initial_phase_value => 0,
dpll_lock_count => 0,
dpll_lock_window => 0,
enable_clock_pin_mode => "UNUSED",
enable_dpa_align_to_rising_edge_only => "OFF",
enable_dpa_calibration => "ON",
enable_dpa_fifo => "UNUSED",
enable_dpa_initial_phase_selection => "OFF",
enable_dpa_mode => "OFF",
enable_dpa_pll_calibration => "OFF",
enable_soft_cdr_mode => "OFF",
implement_in_les => "OFF",
inclock_boost => 0,
inclock_data_alignment => "EDGE_ALIGNED",
inclock_period => 25000,
inclock_phase_shift => 0,
input_data_rate => 480,
intended_device_family => "Cyclone V",
lose_lock_on_one_change => "UNUSED",
lpm_hint => "CBX_MODULE_PREFIX=lvds",
lpm_type => "altlvds_rx",
number_of_channels => 1,
outclock_resource => "AUTO",
pll_operation_mode => "NORMAL",
pll_self_reset_on_loss_lock => "ON",
port_rx_channel_data_align => "PORT_UNUSED",
port_rx_data_align => "PORT_UNUSED",
refclk_frequency => "40.000000 MHz",
registered_data_align_input => "UNUSED",
registered_output => "OFF",
reset_fifo_at_first_lock => "UNUSED",
rx_align_data_reg => "RISING_EDGE",
sim_dpa_is_negative_ppm_drift => "OFF",
sim_dpa_net_ppm_variation => 0,
sim_dpa_output_clock_phase_shift => 0,
use_coreclock_input => "OFF",
use_dpll_rawperror => "OFF",
use_external_pll => "ON",
use_no_phase_shift => "ON",
x_on_bitslip => "ON"
--clk_src_is_pll => "off"
PORT MAP (
rx_enable => enaclock,
rx_in => AD9222_D(I TO I),
rx_inclock => fastclock,
rx_out => rx_out(I)
PROCESS (slowclock, reset)
BEGIN
IF rising_edge(slowclock) THEN
reg1(I) <= rx_out(I);
reg2(I) <= reg1(I);
reg3(I) <= reg2(I);
END IF;
END PROCESS;
PROCESS (outclock, reset)
BEGIN
IF reset = '1' THEN
lvds_rx(I) <= (others => '0');
ELSIF rising_edge(outclock) THEN
lvds_rx(I) <= reg2(i) & reg1(i);
END IF;
END PROCESS;
--- Quote Start --- I'm using x6 SERDES and combining 2x6Bit to 12 Bit output at half slowclock rate. 12-Bit ADC with LVDS output at 480 MHz LVDS/40 MHz output data rate. Used code as is --- Quote End --- Thank you, FvM this does make sense.
If your data rate is reasonable you can always write your own deserializer code and make it any length you want.
