21592 Discussions
Cyclone V PLL : "Normal" mode compensation is not working.
It seems I have encountered a Problem with PLLs in Cyclone V devices,
when the PLL is operating in "normal" compensation mode.
According to the Cyclone V manual, a PLL in normal mode should compensate the
delay of a global clock network in such a way, that the clock routed via the global
network should reach all the destination registers (almost) co-incident to the
external reference input of the PLL.
For Cyclone 1 and Cyclone IV devices, that seems to work as expected.
But for Cyclone V devices, the TimeQuest analysis says that this does not work at all.
Even worse some tests with real Cyclone V hardware suggest that TimeQuest is not
(completely) wrong: It seems that somehow the "normal" compensation mode does
not work as expected.
I put two mini example designs for Cyclone IV and Cyclone V here:
http://www.lauterbach.com/support/static/altera_tco_tests.zip
Both designs were compiled with Quartus II 16.1.0 (Build 196 10/24/2016).
My guess is, that the Quartus II version, does not really matter
(I expect the problem to appear with any Quartus II version).
For both designs you can get a timing analysis, by opening TimeQuest
and then running "Script->report_timing.tcl".
I am particularly interested in the
slow and fast corner "WITH PLL" panels.
The part of the design I am interested in does this:
GLOBAL CLK NET iClk -> PLL ----------> I/O Register ----> Pin rDataB oDataB
I am measuring the delay from a rising edge on
iClk to the output on the Pin ( oDataB ) ;
so the clock-to-output time.
Note:
iClk is supposed to have 50Mhz, the PLL output is
also 50Mhz; the PLL is just used to compensate the
delay of the global clock network.
The essence (the part which I am worried about) is this:
For Cyclone IV devices TimeQuest reports a clock path delay
(from the input clock reference pin to an I/O register) of:
- fast corner: -0.298
- slow corner: 0.214
This is what I would expect:
The compensation keeps the delay close to 0ns. For the fast corner
you get a negative "delay", because the PLL over-compensates.
For Cyclone V devices TimeQuest reports the same kind of clock path delay as:
- fast corner: 0.591
- slow corner: 3.219
Especially the slow corner seems to indicate, that the PLL
is not compensating much.
Now I am wondering what am I doing wrong ?
Is this a known issue with Cyclone V devices ?
