21607 Discussions
Cyclone V SoC custom board preloader boot sdram test issue
BrianSune_Froum
New Contributor II
Dear Intel FAE and ALL,
This is Brian and having issue on maximum 2GB DDR3 boot sanity test.
There is a warning like these:
"SDRAM: Running EMIF Diagnostic Test ...Iteration 1734:, expect 0x20a69210 from address 0x20a69213, read 0x20a69210 insteadFailed"
But w/o the SDRAM test on preloader, the system can boot into distro and passed memtester.
Do the preloader have any bug on the memory size of the SDRAM?
It do show a 2048M size message.
memtester log:
brian@brian:~$ sudo memtester 1900M
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 1900MB (1992294400 bytes)
got 1900MB (1992294400 bytes), trying mlock ...locked.
Loop 1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 2:
Stuck Address : setting 3^C
JingyangTeh_Altera
Hi
Could you share what uboot version that you are using?
There is no known issue for the recommended uboot version socfpga_v2024.07.
Jingyang, Teh
BrianSune_Froum
New Contributor II
@JingyangTeh_Altera
The work stations are in Quartus 18.1.
So the uboot is generated via make uboot from bsp-editor MakFile.
Do you mean even the EDA is 18.1 the ARM development can still updated to latest?
I am not too sure on uboot, as for the kernel it is using most latest 6.12.11 dirty.
The DDR3 2GByte is fully tested on distro even ran the frame-buffer w/o any issue.
This is why it is very puzzling why larger than 1GByte will have such issue.
Opps,
I think you had misunderstand the issue point correct me if I misunderstand.
The issue is happened on "preloader" dram check not uboot phase?
The check is ran via the spl.c on the sdram check function if I understood it right.
JingyangTeh_Altera
Hi
Apologize for the late reply.
For the new flow the SPL s no longer generated from the bsp-editor.
The SPL version is tied together with the u-boot version.
It is still separate from the uboot. ( https://github.com/altera-fpga/u-boot-socfpga/blob/socfpga_v2024.07/arch/arm/mach-socfpga/spl_gen5.c)
In the latest spl code, there is no longer sdram diagnostic test.
New flow:
https://altera-fpga.github.io/rel-25.1.1/embedded-designs/cyclone-v/sx/soc/boot-examples/ug-linux-boot-cve-soc/#the-new-flow
Jingyang, Teh
BrianSune_Froum
New Contributor II
@JingyangTeh_Altera
Allow me, based on my ultra lite knowledge on U-Boot and SPL.
The DDR_SI test actually can be transferred from old U-Boot to latest mainstream Das U-Boot (Altera U-Boot).
According to Siemens patches I do see s.t. very similar.
This is just feature that Altera plan to do so or not.
Apart from U-Boot version I cannot see such test is very complex compared to old 2013 trunk.
Meanwhile, the U-Boot itself from mainstream already included calibration of SDRAM, but had not study deep on such test.
BrianSune_Froum
New Contributor II
@JingyangTeh_Altera
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
