Cyclone V
Hello.
It is necessary to accept a serial code with a speed of 768 Mbps and to transform it to a parallel 8-bit code with a frequency of 96 MHz.
Proceeding from an objective, what IP-core you will recommend to use?
There were attempts of implementation of this project on Custom PHY Tranciever. There were following questions:
1) How there is a synchronization at reception of serial signal? (How I can organize this synchronization?)
2) When using Custom PHY Tranciever is it possible to use only levels 1.5 PCML?
3) Do you have any recommendations for realization of this problem?
I use next equipment:
- Cyclone V GX Starter Kit
The used software:
- Quartus II 13.1 (64-bit)
