21592 Discussions
Cyclone10LP extended temperature support
shawn-tang
Hello experts,
I'm using Cyclone10LP 10CL016YU256I7G on my products. On the datasheet, we found this chip can support "Extended Industrial" temperature.
At this page(https://www.intel.com/content/www/us/en/products/programmable/temperature.html), it is described that  how to perform timing analysis for an I7 speed grade at the extended junction temperature range -40°C to 125°C". But I did not find the related setting on Quartus Prime lite and standard version(21.1).
My question is: how to evaluate if this chip can operate at extended temperature in my application?   Can I get some guideline?  thanks!
Br,
Shawn Tang
AqidAyman_Intel
Hi Shawn,
Can you share how you do the setting?
As per check, the settings are available inside the Quartus for the device.
Aqid
AqidAyman_Intel
Hello Shawn,
I wish to check with you, do you have any more concern on this?
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
