Is is possible for the Cyclone3 to drive out true LVDS with a clock at 240MHz drive data at both the rising and falling edges of that clock, DDR like? I see in the data sheet that it can do true LVDS on the left and right sides w/o the need of the external resistor networks, but trying to get an idea of speed. Regards, RobLink Copied
It's all in the Cyclone III device handbook. The maximum I/O clock rate for true LVDS output is between 320 and 420 MHz, depending on the device speed grade.
