21613 Discussions
DAC (DAC5672) and ADC (AD9254) in VHDL
i have a project in which i need to create the VHDL code for a DAC (DAC5672) and an ADC (AD9254).
It is part of a CDMA.
The DAC must incorporate a 2's complement and the ADC must incorporate an offset binary.
This is what i have so far :
this is my adc which i am pretty sure will work ok :
entity adc is port(
clk : in std_logic;
adc_out : out std_logic_vector(13 downto 0);
analog_in : in std_logic_vector(13 downto 0)
end adc;
architecture behavioral of adc is
signal msb : std_logic;
begin
process(clk)
begin
if(clk'event and clk ='1') then
adc_out(12 downto 0) <= analog_in(12 downto 0);
msb <= analog_in(13);
adc_out(13) <= not msb;
end if;
end process;
end behavioral;
this is my dac which i am pretty sure is no good :
entity dac is port(
clk : in std_logic;
digi_in : in std_logic_vector(13 downto 0);
analog_out : out std_logic_vector(13 downto 0)
end dac;
architecture behavioral of dac is
signal analog_signal : std_logic_vector(13 downto 0);
begin
process(clk)
begin
analog_signal <= digi_in;
analog_signal <= not(analog_signal) + "00000000000001"; -- complément à 2
end if;
end process;
analog_out <= analog_signal;
end behavioral;
Please could someone point me in the right direction for either of the codes if they think something could be made better ?
Well, the code for the ADC controller is wrong. The msb of adc_out is delayed by and extra clock cycle compared to the rest of the word.
And in your ADC code, your analog_out is just a counter (that will actually not work in simulation). This is because you have assigned analog_signal to digi_in, but then overridden this assignment.. In VHDL, signals get assigned the last thing assigned to them. They are not like variables that are updated immedietly
ok, so for the ADC, would this work ?
adc_out(13) <= not analog_in(13);
end if;
Now the MSB and the rest of the word are synchronised right ?
And for the DAC, would it be better to replace analog_signal directly with analog_out ?
Although i don't see how this will convert a digital signal to an analogue signal...
--- Quote Start ---
end if;
--- Quote End ---
Yes, now synchronised
--- Quote Start ---
--- Quote End ---
Note quite. You'll still have the same problem. Ill let you think about it....
--- Quote Start ---
--- Quote End ---
It wont, unless this is the number format that your external DAC chip requires.
Would this do ?
process(clk)
begin
analog_out <= not(digi_in) + "00000000000001"; -- complément à 2
end if;
end process;
I don't think this is right because i'm not sure i can directly send the in to the out of the DAC, i think i have to go through a signal (which is why i did the code like that in the first place) but like this analog_out is only assigned once and is not overwritten i think ?
This is correct in that analog out has been inverted properly.
But you are getting confused. An FPGA cannot have any analogue inputs or outputs. The input/output is digital. The external DAC and ADC will do the conversion.
Ok, thanks you for your help.
Yes, now that you say, i understand.
I will now create some test benches and see what it gives me.
