21611 Discussions
DC Coupled LVPECL
I am trying to feed an LVPECL output from an Si5338 into an LVPECL clock input of an Arria V. The Vicm and Vid of both chips are compatible.
Can I just DC-couple the output of the Si5338 and the input of the Arria V, using a single 100 ohm resistor between the Arria V clock pins?
Thank you for your help!
