When I tried to fit my design into Cycleon II, I got an error message
Error: DQS I/O pin "ddr2_dqs[1]" does not feed a Clock Delay Control block I use Altera's DDR2 controller, why does this happen? Do I need put a "altdqs" megafunction between the DQS output of the DDR2 Controller and the DQS pin on FPGA?Link Copied
I've the same problem. Do you know the solution?
