21602 Discussions
DDR3 UniPHY problems
I am trying to incude a DDR3 UniPHY Controller megacore to my design, but I am experiencing several issues. I am working on a TR4 development kit (TERASIC) based on the STRATIX IV FPGA (EP4SGX530KH40C2).
Basically I have generated the Megacore by using the Megawizard plug-in manager, I have parametrized my DDR3 block and I have generated the entity for my design.
After this I have normally instantiated the DDR3_Controller by defining it as a component inside my VHDL code, and I have connected it to the right signals. In addition I have mapped them to the pins on my development board by using the pin planner.
I haven´t still developed a control logic to drive the controller but this shouldn´t be a problem.
When I try to compile my design, it already fails in the Analysis and Synthesis step, and I get the following errors:
Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RUP port, which must be connected to an I/O atom in input mode Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RUP port, which must be connected to a dedicated I/O atom with no other fanout Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RDN port, which must be connected to an I/O atom in input mode Error (15700): Termination calibration block atom "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|altera_mem_if_oct_stratixiv:oct0|sd1a_0" uses RDN port, which must be connected to a dedicated I/O atom with no other fanout Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15853): Input port IBAR of I/O input buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|strobe_in" must be driven by a top-level pin Error (15065): Clock input port inclk of PLL "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_pll0:pll0|altpll:upll_memphy|altpll_8nd3:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Info (15024): Input port INCLK of node "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_pll0:pll0|altpll:upll_memphy|altpll_8nd3:auto_generated|pll1" is not connected Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin Error (15856): Output port O of I/O output buffer "SDRAM_Controller:b7|SDRAM_Controller_0002:sdram_controller_inst|SDRAM_Controller_p0:p0|SDRAM_Controller_p0_memphy:umemphy|SDRAM_Controller_p0_new_io_pads:uio_pads|SDRAM_Controller_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiv:altdq_dqs2_inst|obuf_os_bar_0" must drive a top-level pin
What is the problem here? How can I fix this?
I am getting problems both by compiling the examples automatically generated by the Megacore, and the examples developed with my board are quite bugged and fully not working...
BR,
Giovanni.
Hi Giovanni,
you have to launch a .tcl script to complete the constraint file
for the DDR3 pins. It is something like <your_controller_name>_p0_pin_assignments.tcl
hope this could solve your problem,
regards,
