21600 Discussions
DDR3 memory controller endianess
I've implemented a Half Rate DDR3 controller on a Cyclone V FPGA.
There're 32 DQ lines - so the internal bus width is 128 bits (for WRITEDATA as well as READDATA).
The address width is 26 bits.
Now, because the DDR3 holds only 32 bits (and not 128) in each cell - the cell address is 28 (and not 26) bits wide.
So - when I issue a read command to binary address: 0b"0000_0000_0000_0000_0000_0000_00" the controller fetches back the values from cells:
0b"0000_0000_0000_0000_0000_0000_0000"
0b"0000_0000_0000_0000_0000_0000_0001"
0b"0000_0000_0000_0000_0000_0000_0010"
0b"0000_0000_0000_0000_0000_0000_0011"
My question is:
Suppose the DDR cells with the above address - hold the following data:
0b"0000_0000_0000_0000_0000_0000_0000" => 0x00000001
0b"0000_0000_0000_0000_0000_0000_0001" => 0x00000002
0b"0000_0000_0000_0000_0000_0000_0010" => 0x00000003
0b"0000_0000_0000_0000_0000_0000_0011" => 0x00000004
Assuming READDATA is defined as 127 downt to 0 (the leftmost bit is the LSB )- How will its content look like?
Will it be:
0x 00000001_00000002_00000003_00000004
or
0x 00000004_00000003_00000002_00000001
