As for the DDR3 clock frequency, it's currently set to 533Mhz (max allowed freq). I know that the minimal supported frequency is 300MHz. So, can I set any frequency between 300MHz and 530Mhz? Why does the minimum frequency requirement exist at all? I'm working with ArriaV SX and the on-board DDR3 memory is Micron MT41K256M16HA-125IT. Thank you!Link Copied
i believe is that that allow some margin for some clock variation due to PCB design. It is the best you configured to a frequency at the middle, as due to temperature constraint, the frequency might be vary....
--- Quote Start --- So, can I set any frequency between 300MHz and 530Mhz? --- Quote End --- Providing your chosen DDR3 memory devices supports your selection, yes. --- Quote Start --- Why does the minimum frequency requirement exist at all? --- Quote End --- The DDR3 memory's DLL will have a minimum operating frequency, below which it won't lock. Cheers, Alex
