Hi
May I see your DDR3 IP setting from the GUI?
You can provide the snapshot of the IP GUI and put it in this forum.
Can you share the calibration report from the memory toolkit for calibration fail?
You can generate the report by clicking on Generate All Report in the toolkit.
Adzim
Thank you for replying to me
this is my project
The hardware was drawn by my colleague, and the control lines are not of equal length. The others are of equal length. Currently, I don't know if it's a hardware or software issue. How can I debug to see the timing of DDR3 operation
this is my Calibration Report
now my init sometime is sucess,sometime is fail
sucess is follow picture
fail is follow picture
Hi
You may calculate the board skew and enter the details in the IP.
This margin from toolkit doesn't look okay. Maybe the issue is with the signal integrity on the board.
You also can check the clock stability and voltage level on the board.
Adzim
