Programmable Devices
21615 Discussions
DE0-Nano Accelerometer code help (almost there)
Can anyone spot the problem with my VHDL-code please?
I pasted it at the pastebin because it was over 1000 lines:rolleyes:
http://pastebin.com/draraqr7
Line 384 and 480
-- data1(7) <= I2C_sdat; -- SOMETHING WRONG HERE:
CANT RESOLVE MULTIPLE CONSTANT DRIVERS FRO NET "q" (line 54)
This was the original verilog code:
// ADXL clock= 500,000samples of 50Mhz/100Hz // ADXL address= 0x1D/11101 (alt address pin grounded) module ADXL_Read(clk_50, I2C_sclk, I2C_sdat, key0, key1, clk_st, data1); input clk_50; output I2C_sclk; output data1; inout I2C_sdat; input key0; //Trigger0 to reset input key1; //Trigger1 to begin output clk_st; reg a; reg b; reg clk; //Clk for slave reg clk_signaltap; //Clk for signaltap2 reg q; //Register for Trigger reg step; reg sl_ad = 7'b0011101; // Slave Address reg reg_ad = 8'h2D; // Register Address reg data1; // Databyte#1 reg sclk; reg sdat; initial begin step = 0; q = 0; end always @(posedge clk_50) begin if(a == 1000000) //Clock for Slave with sample 2a begin clk = ~clk; a = 1; end else a = a + 1; //Signaltap begin if(b == 500000) //Clock for Signaltap2 begin clk_signaltap = ~clk_signaltap; b = 1; end else b = b + 1; end //Signaltap end always @(posedge clk_50) //Trigger Condition case({!key1, !key0}) //Active low 2'b00 : q <= q; 2'b10 : q <= 1; //Set 2'b01 : q <= 0; //Reset endcase always @(posedge clk) begin if (q == 1) begin case(step) //Initial 0: begin sclk = 1; sdat = 1; step = 1; end //1.Start 1: begin sclk = 1; sdat = 0; step = 2; end 2: begin sclk = 0; sdat = 0; step = 3; end //2.Slave add 3: begin sclk = 0; sdat = sl_ad; step = 4; end 4: begin sclk = 1; sdat = sl_ad; step = 5; end 5: begin sclk = 0; sdat = sl_ad; step = 6; end 6: begin sclk = 1; sdat = sl_ad; step = 7; end 7: begin sclk = 0; sdat = sl_ad; step = 8; end 8: begin sclk = 1; sdat = sl_ad; step = 9; end 9: begin sclk = 0; sdat = sl_ad; step = 10; end 10: begin sclk =1; sdat = sl_ad; step = 11; end 11: begin sclk = 0; sdat = sl_ad; step = 12; end 12: begin sclk = 1; sdat = sl_ad; step = 13; end 13: begin sclk = 0; sdat = sl_ad; step = 14; end 14: begin sclk = 1; sdat = sl_ad; step = 15; end 15: begin sclk = 0; sdat = sl_ad; step = 16; end 16: begin sclk = 1; sdat = sl_ad; step = 17; end //3.sdat = 0 17: begin sclk = 0; sdat = 0; step = 18; end 18: begin sclk = 1; sdat = 0; step = 19; end //4.Acknowledge 19: begin sclk = 0; sdat = 1'bz; step = 20; end 20: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 20; else step = 21; end //5.Reg add 21: begin sclk = 0; sdat = reg_ad; step = 22; end //7 22: begin sclk = 1; sdat = reg_ad; step = 23; end 23: begin sclk = 0; sdat = reg_ad; step = 24; end //6 24: begin sclk = 1; sdat = reg_ad; step = 25; end 25: begin sclk = 0; sdat = reg_ad; step = 26; end //5 26: begin sclk = 1; sdat = reg_ad; step = 27; end 27: begin sclk = 0; sdat = reg_ad; step = 28; end //4 28: begin sclk = 1; sdat = reg_ad; step = 29; end 29: begin sclk = 0; sdat = reg_ad; step = 30; end //3 30: begin sclk = 1; sdat = reg_ad; step = 31; end 31: begin sclk = 0; sdat = reg_ad; step = 32; end //2 32: begin sclk = 1; sdat = reg_ad; step = 33; end 33: begin sclk = 0; sdat = reg_ad; step = 34; end //1 34: begin sclk = 1; sdat = reg_ad; step = 35; end 35: begin sclk = 0; sdat = reg_ad; step = 36; end //0 36: begin sclk = 1; sdat = reg_ad; step = 37; end //6.Acknowledge 37: begin sclk = 0; sdat = 1'bz; step = 38; end 38: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 38; else step = 39; end //7.Start 39: begin sclk = 0; sdat = 0; step = 40; end //sclk= 0, sdat= 0 40: begin sclk = 1; sdat = 1; step = 41; end //sclk= 1, sdat= 1 41: begin sclk = 1; sdat = 0; step = 42; end //sclk= 1, sdat= 0 42: begin sclk = 0; sdat = 0; step = 45; end //sclk= 0, sdat= 0 --------------- //8.Slave Add 45: begin sclk = 0; sdat = sl_ad; step = 46; end //6 46: begin sclk = 1; sdat = sl_ad; step = 47; end 47: begin sclk = 0; sdat = sl_ad; step = 48; end //5 48: begin sclk = 1; sdat = sl_ad; step = 49; end 49: begin sclk = 0; sdat = sl_ad; step = 50; end //4 50: begin sclk = 1; sdat = sl_ad; step = 51; end 51: begin sclk = 0; sdat = sl_ad; step = 52; end //3 52: begin sclk = 1; sdat = sl_ad; step = 53; end 53: begin sclk = 0; sdat = sl_ad; step = 54; end //2 54: begin sclk = 1; sdat = sl_ad; step = 55; end 55: begin sclk = 0; sdat = sl_ad; step = 56; end //1 56: begin sclk = 1; sdat = sl_ad; step = 57; end 57: begin sclk = 0; sdat = sl_ad; step = 58; end //0 58: begin sclk = 1; sdat = sl_ad; step = 59; end //9.sdat = 1 59: begin sclk = 0; sdat = 1; step = 60; end 60: begin sclk = 1; sdat = 1; step = 61; end //10.Acknowledge 61: begin sclk = 0; sdat = 1'bz; step = 62; end 62: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 62; else step = 63; end //11.Databyte#1 63: begin sclk = 0; sdat = 1'bz; step = 64; end //Databyte#1 bit 7 64: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 65; end 65: begin sclk = 0; sdat = 1'bz; step = 66; end //6 66: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 67; end 67: begin sclk = 0; sdat = 1'bz; step = 68; end //5 68: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 69; end 69: begin sclk = 0; sdat = 1'bz; step = 70; end //4 70: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 71; end 71: begin sclk = 0; sdat = 1'bz; step = 72; end //3 72: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 73; end 73: begin sclk = 0; sdat = 1'bz; step = 74; end //2 74: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 75; end 75: begin sclk = 0; sdat = 1'bz; step = 76; end //1 76: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 77; end 77: begin sclk = 0; sdat = 1'bz; step = 78; end //0 78: begin sclk = 1; sdat = 1'bz; data1 = I2C_sdat; step = 79; end //12.Acknowledge 79: begin sclk = 0; sdat = 1'bz; step = 80; end 80: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 80; else step = 81; end //13.Stop 81: begin sclk = 1; sdat = 0; step = 82; end //sclk= 1, sdat= 0 82: begin sclk = 1; sdat = 1; step = 83; end //sclk= 1, sdat= 1 83: begin sclk = 1; sdat = 1; end endcase end end assign I2C_sclk = sclk; assign I2C_sdat = sdat; assign clk_st = clk_signaltap; endmodule
Your two line codes after the "begin" (lines 52 and 53) don't define initial conditions, as I guess is doing the "initial" block in the Verilog code, but is permanently assigning the values "00000000000" and '0' to step and q.
You may want to put those initialisations in a reset part in each process, or just define the initial value when you declare the signal. This, for example: SIGNAL q : STD_LOGIC := '0'; SIGNAL step : STD_LOGIC_VECTOR(10 DOWNTO 0) := (others => '0');
Don't understand what you mean with -- SOMETHING WRONG HERE and why the final signal assignments are commented.
Verilog Initial block is exactly represented by the initializers Daixiwen suggested. Initialization to 0 is only required for simulation purposes, hardware registers are initially zeroed without an explicite initializer.
TO_BE_DONE
Hi
I am working with De0-Nano, you can help me with VHDL code for accelerometer?
you have it available for me send?
Thank you
Nouara
Hi sindredit
This link not found. You have mail?
