21592 Discussions
DE2-115 using GPIOs
I am trying to build a simple example which uses a statemachine to change a bit and then send that bit as an output to the GPIO. I am using a DE@-115 board with Quartus IIversion 13. I am using a Saleae logicdevice to monitor the GPIO outputs. Attachedis my code.
Things that work:
Switches control LEDR.
KEY controls LEDG.
Assigning a SW(2) to the GPIOoutput myBit2 works. I can see theoutput change when I flip the switch during capture.
Assigning a KEY to myBit works.
What doesn’t work:
Assigning clk to myBit
Assigning data to myBit2 fromthe state machine
Task:
To control a GPIO output logiclevel with software.
LIBRARY ieee; USE ieee.std_logic_1164.all; entity part is Port ( clk : in STD_LOGIC:='0'; SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); LEDR : OUT STD_LOGIC_VECTOR(17 DOWNTO 0):="000000000000000000"; -- red LEDs LEDG : OUT STD_LOGIC_VECTOR(8 DOWNTO 0):="000000000"; -- green LEDs KEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0); myBit, myBit1, myBit2, myBit3 : out STD_logic); --GPIO 0, 1, 2, 3 end part; architecture Behavioral of part is signal clk1 : STD_LOGIC:='0'; signal clkout:std_logic:='0'; --clk <= clk; type state is(state1,state2,state3,state4,state5,state6,state7,state8,state9,state10); signal current_state,next_state:state; signal data:std_logic:='1'; begin Clock : process(clk1, clkout) begin if clk1 <= 'U' then clk1 <= '0' after 2 us; else clk1 <= not clk1 after 2 us; end if; if clkout <= 'U' then clkout <= '0' after 2 us; else clkout <= not clkout after 2 us; end if; end process; process(clkout) begin current_state<=next_state; end process; process(current_state,next_state) begin case current_state is when state1=> data <='0'; next_state<=state2; when state2=> data <='1'; next_state<=state3; when state3=> data <='1'; next_state<=state4; when state4=> data <='1'; next_state<=state5; when state5=> data <='1'; next_state<=state6; when state6=> data <='1'; next_state<=state7; when state7=> data <='0'; next_state<=state8; when state8=> data <='0'; next_state<=state9; when state9=> data <='1'; next_state<=state10; when state10=> data <='1'; next_state<=state1; end case; myBit3 <= data; end process; LEDG(7) <= KEY(3); LEDG(5) <= KEY(2); LEDG(3) <= KEY(1); LEDG(1) <= KEY(0); LEDR(0) <= SW(0); LEDR(1) <= SW(1); LEDR(2) <= SW(2); LEDR(3) <= SW(3); myBit <= SW(0); myBit2 <= SW(2); end Behavioral;
Where is your output assignment to the GPIO?
