21611 Discussions
DE2 - video to VGA in VHDL
hello,
Important point to understand my concerns, I am European (vhdl and pal).
I am using a DE2 board and I wanted to start transferring the video input to VGA output.
For this I used the program DE2_TV cdrom.
But I get nothing out!
In fact I get a picture in case I go back to NTSC but the image contains only saturated RGB colors, very ugly !
I was not able to measure the frequency on pin 14 of the VGA :oops:
In addition, the codes are in verilog and I usually work in vhdl.
In a second step I decided to use DE2_Default (work on an image to start) included on the CDROM, but I do not know how to get from an image file. Hex?
and the code is still in verilog ...
My questions:
Is there a version of vhdl DE2_TV and works in PAL and can you explain the behaviors and problems I encounter?
Why the project is there no file VGA_Param.h when he is in DE2_Default ?
Maybe he should copy the folder VGA_controller?
Is there a program to convert an image in hex​​ ?
Where is the documentation of his examples ?
And do you know if there is a version of vhdl examples?
If there are no equivalent programs in vhdl I can include my code in vhdl in the original project in verilog?
Can you tell me how (the method) and where in the verilog code I have to do :confused:
I wish the final apply filters on a simple image you links to examples of this type with the DE2 board and vhdl ?
Thank you in advance for your answers.
nv
Have you solved the prolem? do you have vhdl code for DE2 that configures the board for PAL in VGA out?
pzorea.
--- Quote Start ---
hello,
My questions:
nv
--- Quote End ---
Thanks, but since the Video decoder configuration done via I2C...I couldn't find the driver/block for I2C protocol...say, how can I load the configuration data to the Video decoder?
