I’m having a problem with the NIOS processor in the design. It looks like the Avalon bus is getting stuck on different memory accesses. For a long time it was on the instruction master but the last few builds it’s been on the data master. I’ve been changing settings in the .qsys system as well as in the BSP and some of them are changing where the issue occurs but I’m constantly seeing something like the attached image where the NIOS is attempting a read but waitrequest is held high forever. In the case below, the data master is attempting to read from the EPCQ avl_csr. But I’ve also seen it happening when the instruction master is attempting to read from the on chip ram.
I’ve attempted some debugging with system console and a JTAG to Avalon master. I tried the following commands:
% set jd_path [lindex [get_service_paths jtag_debug] 0]
/devices/10AX048E(1|2|3|3ES|4|4ES)|..@1#USB-0/(link)/JTAG/(110:132 v1 #0)/phy_0
% jtag_debug_reset_system $jd_path
any suggestion?
No attached image. Did you forget to attach the picture of your system design?
I'm going to check with my client to see if they can provide me with an image.
Could you also post the Quartus design?
Any update from your side?
hi,
the client still hasn´t answered me, please give me a few more days to see if he answers.
regards.
Thanks, please help to post the update once you have them.
You may also just upload the archive or .qsys file for me to check.
Any update from your client for this week?
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
