21592 Discussions
Does Megawizard has block have multiple cycle delays which can be specified?
I know there is a block named LPM_FF, this is a register can make the input signal to output one cycle delay. But I want to specified cycle delays, such as 32 or 64, I wonder whether there is a block I can specified the input delay cycles?
Hi, what version do you use ?
do you have LPM_SHIFTREG and Shift Reg (RAM-based).
Whith the "Shift Reg (RAM-based)" you can configure the distance between shiftin and shiftout and optionally add taps.
Yes,I have. I think Shift Reg is what I want. Thanks.
