21605 Discussions
Does Quartus 20.1 std support VHDL 2008 vector aggregation?
zhenge
I have something like the following:
signal_a(7 downto 0) <= (3 downto 0 => "0001", others => '1');
I got error:
Error (10515): VHDL type mismatch error at ***.vhd(###): std_ulogic type does not match string literal
Please comment
RichardTanSY_Altera
I believe you are correct - Quartus Standard does not support aggregates for VHDL 2008 due to its limited language support. The following list is the closest I could find of VHDL 2008 features that Quartus Standard supports, prior to the release of Quartus Pro version:
https://www.intel.com/content/www/us/en/programmable/quartushelp/16.0/index.htm#hdl/vhdl/vhdl_list_2008_vhdl_support.htm
I have try to run below code (Fail in Standard but Pass in Pro):
library ieee;
use ieee.std_logic_1164.all;
entity Example is
 port (
  clk : in std_logic;
  reset : in std_logic;
  out_data : out std_logic_vector(7 downto 0)
end entity Example;
architecture Behavioral of Example is
 signal signal_a : std_logic_vector(7 downto 0) := (others => '1');
begin
 process (clk, reset)
 begin
  if reset = '1' then
   -- reset the signal to the initial value
   signal_a <= (3 downto 0 => "0001", others => '1');
  elsif rising_edge(clk) then
   -- do some processing using the signal
   out_data <= signal_a;
  end if;
 end process;
end architecture Behavioral;
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
RichardTanSY_Altera
library ieee;
entity Example is
 port (
  clk : in std_logic;
end entity Example;
begin
 begin
  if reset = '1' then
  end if;
 end process;
Richard Tan
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
Richard Tan
