21615 Discussions
Does the Arria® 10 transceiver support spread spectrum?
善丁
Our project plans to use the Arria® 10 transceiver to receive signals from the sender. The problem is that the signal at the transmitting end is a Spread Spectrum signal with an amplitude of 3% and a modulation frequency of 100 kHz. We want to know if the Arria® 10 transceiver can meet the above requirements. Thank you!
Nathan_R_Intel
Arria 10 has not been validated with SSC for non-PCIe application usage. Hence, its not within Arria 10 specs.
For PCIe applications, Arria 10 can meet the SSC requirement per PCIe spec​
