21611 Discussions
Download a design with SRAM Object File containing this instance
Hi guys,
I am unable to run the signal tap as it shows the instance not found message on STP.
1. I cross verified that STP is enabled and linked to project.
2. Deleted db and incremental db folders.
I am unable to know the root cause of the issue.
If anyone faced same problem please share it.
Thanks in advance.
Ramesh
