- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am trying to download the Altera Verification IP Suite User Guide Version 2.0 January 2011 and its accompanying design file. But I am being directed to the latest Version 3.0 and design file if I use the link below:
http://www.altera.com/literature/ug/ug_avalon_verification_ip.pdf Is there a server with all previous versions of a document? I need the older version because the new one's tutorial is making use of QSys to verify a device with Avalon-ST, but I want to use SOPC Builder instead. I have not moved to QSys yet.링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
if possible, please feed this back to Altera. i have had similar problems
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for the files Dave. Have you just dowloaded them from somewhere or do you just happen to have these files on your computer?
To get to the verification tool itself, I was able to run the tutorial files. Now I want to do the same thing on my own component which has Avalon ST interface. I followed all the steps until I reach page 13-5, Step 11: 'In the Compile Source Files dialog box, select st_bfm_top.v and click Compile. Next select st_bfm_sopc.v and click Compile. Finally, select st_bfm_test.v and click Compile.' Do I have to manually write these top level test modules for my component or can they be automatically generated? If the latter, how? Thanks- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Have you just dowloaded them from somewhere or do you just happen to have these files on your computer? --- Quote End --- I had copies on my computer. --- Quote Start --- To get to the verification tool itself, I was able to run the tutorial files. Now I want to do the same thing on my own component which has Avalon ST interface. I followed all the steps ... --- Quote End --- Ignoring the VIP manual, here's what I do. I create an SOPC System with the Avalon BFM components, and then I let Quartus generate the simulation scripts for me (check the checkbox in SOPC Builder before clicking generate), eg., for a system called sopc_builder, a folder called sopc_builder_sim will be created in your project folder. Within that folder is a setup_sim.do script. Use this as a template for a new Tcl script to build the sopc_system files. Throw everything else away. Within the generated sopc_system.v file, there is a testbench. Ignore it, its useless (well, mostly useless, see the comment below). Create your own SystemVerilog testbench and instantiate a copy of the sopc_system. Use the hierarchical path to the BFMs to call their Verification IP API functions. I've only been working with Avalon-MM BFM masters, but this technique should work with Avalon-ST BFM masters too. The key thing to understand is that the Verification Suite cannot read your mind, so the automatic testbench it provides is pretty simple, but only because it has to be. Just think of it as a tool compilation test, i.e., you can build the design with Modelsim and vsim it, but it does not do anything interesting, eg., like actually test your design :) Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- I create an SOPC System with the Avalon BFM components, and then I let Quartus generate the simulation scripts for me (check the checkbox in SOPC Builder before clicking generate), eg., for a system called sopc_builder, a folder called sopc_builder_sim will be created in your project folder. Within that folder is a setup_sim.do script. Use this as a template for a new Tcl script to build the sopc_system files. Throw everything else away. Within the generated sopc_system.v file, there is a testbench. Ignore it, its useless (well, mostly useless, see the comment below). Create your own SystemVerilog testbench and instantiate a copy of the sopc_system. Use the hierarchical path to the BFMs to call their Verification IP API functions. --- Quote End --- Thanks for the suggestions Dave. I've followed the initial steps but got lost at the stage of creating my own SystemVerilog testbench because I don't how how to write it. I looked at SystemVerilog tuts and I could only write the lines below. Could anybody give a few pointers on how to do the full testbench code?
// console messaging level
`define VERBOSITY VERBOSITY_INFO
//BFM related parameters
`define ST_SYMBOL_W 8
`define ST_NUMSYMBOLS 1
`define ST_CHANNEL_W 1
`define ST_ERROR_W 1
`define ST_READY_LATENCY 0
//local parameters
`define ST_DATA_W `ST_SYMBOL_W * `ST_NUMSYMBOLS
module learn_verification_ip_test();
import verbosity_pkg::*;
endmodule
The module I want to test is a University Program IP module called Video Edge Detection (see attachment) which takes in 8-bit values and outputs 8-bit values as well. But the module takes in a series of data values to represent a frame of data values. I found out that $readmemh is useful in my case. I want to be able to read the data values from a text file using $readmemh, and write the results also back to another text file. Will I be able to do that in SystemVerilog and BFM? As I couldn't get anywhere with the BFM components, I tried creating a testbench for that component as below without using BFM or SystemVerilog. But here again, I don't think it is good as I am not getting any meaningful results when I try to run it in ModelSim. Any suggestion is greatly appreciated.
// Simulation tool : ModelSim-Altera (Verilog)
`timescale 1 ps/ 1 ps
module main_edge_detection_streaming_vlg_tst();
// constants
// general purpose registers
reg eachvec;
// test vector input registers
reg clk;
reg in_data;
reg in_empty;
reg in_endofpacket;
reg in_startofpacket;
reg in_valid;
reg out_ready;
reg reset;
// wires
wire in_ready;
wire out_data;
wire out_empty;
wire out_endofpacket;
wire out_hw_counter;
wire out_startofpacket;
wire out_valid;
// assign statements (if any)
main_edge_detection_streaming i1 (
// port map - connection between master ports and signals/registers
.clk(clk),
.in_data(in_data),
.in_empty(in_empty),
.in_endofpacket(in_endofpacket),
.in_ready(in_ready),
.in_startofpacket(in_startofpacket),
.in_valid(in_valid),
.out_data(out_data),
.out_empty(out_empty),
.out_endofpacket(out_endofpacket),
.out_hw_counter(out_hw_counter),
.out_ready(out_ready),
.out_startofpacket(out_startofpacket),
.out_valid(out_valid),
.reset(reset)
reg storage_values ; //153600 values for 640x240 image
integer fileId, fileOutput;
initial
begin
// code that executes only once
clk = 1'b1;
// Do the hexadecimal reads from the txt file
$readmemh("hexval_test_1d.txt", storage_values);
// ouput result will be sent to a text file
fileOutput = $fopen("result_sobel.txt", "w");
reset = 1'b0;
in_empty = 1'b1;
in_startofpacket = 1'b1;
in_valid = 1'b1;
in_endofpacket = 1'b0;
//in_ready = 1'b1;
//Stop after 1536000 clock cycles ??# 1536000 in_endofpacket = 1'b1;
$display("Running testbench");
end
// Control the clock signal
initial
begin
forever# 5 clk = ~clk;
end
integer i;
initial
begin
for (i=0; i < 153600; i=i+1)
begin
@(posedge clk);
in_data = storage_values;
$fwrite(fileOutput,"%d\n",out_data);
end
@eachvec;
end
endmodule
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Here's a verification example. The SOPC System contains an Avalon-MM BFM master, an on-chip RAM, and a PIO component. The readme.txt file explains how to rebuild the system.
The SystemVerilog testbench sopc_system_tb.sv in the folder sopc_system_sim/ shows you how to create an instance of your design and issue the BFM calls. Cheers, Dave- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for the example. I will try to learn as much as I can from this. But at step (d) when I type s, I get the following error message:
# ** Error: (vsim-3010) - Module 'sopc_system_tb' does not have a `timescale directive in effect, but other modules do.# Region: /sopc_system_tb/dut/the_master_bfm/master_bfm
Any suggestion on how to handle this error? Thank you.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- But at step (d) when I type s, I get the following error message:
Any suggestion on how to handle this error? --- Quote End --- The vsim command should have a '-t ps' option in its command line, so it should work. I've seen this as a warning in simulations, but not as an error, so perhaps there is an option that can be changed to suppress this error. Which version of Modelsim are you using, i.e., what do you get for vsim -version? Note that the error is in the Altera-generated BFM code. Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am using ModelSim Altera Starter Edition vsim 6.6c Simulator 2010.08 Aug 24 2010.
I don't get the error if I 's' after using do on the generated setup_sim.do. Assuming we get this error cleared, do you think I can still achieve what I'm trying to do, i.e. read values from text file, simulate component, and save output to another text? In your sopc_system_tb.sv file, I can see that I will have to modify the two tasks avalon_write_single and avalon_read_single to be able to do what I want, but I don't know how to do that yet and it does seem a bit complicated for a relatively simple thing to do if I was testing a code in C for example. I was just wondering whether this is the best way for me to test a hardware module. Or perhaps everything is complicated with FPGAs... damn I should have stuck with C coding :)- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- I am using ModelSim Altera Starter Edition vsim 6.6c Simulator 2010.08 Aug 24 2010. --- Quote End --- I'll try it with a Modelsim-ASE version and see what I get. --- Quote Start --- Assuming we get this error cleared, do you think I can still achieve what I'm trying to do, i.e. read values from text file, simulate component, and save output to another text? --- Quote End --- Yep, absolutely. SystemVerilog is both a programming language and a hardware language. Whatever you can do in C/C++, there is something similar in SystemVerilog. You can even link C to SystemVerilog ... but I'm not sure if Modelsim-ASE supports that. --- Quote Start --- In your sopc_system_tb.sv file, I can see that I will have to modify the two tasks avalon_write_single and avalon_read_single to be able to do what I want, but I don't know how to do that yet and it does seem a bit complicated for a relatively simple thing to do if I was testing a code in C for example. I was just wondering whether this is the best way for me to test a hardware module. Or perhaps everything is complicated with FPGAs... damn I should have stuck with C coding :) --- Quote End --- I suspect you were just doing simple C code. The real world is much more complicated. Testing code at the component level, and then at the system-level takes extra effort. But that effort pays off big-time when you do not have to debug difficult problems; you avoided them by putting in the extra work up-front. For example, when you write C code, do you write 'unit tests' to ensure that every C function does what it is supposed to do given correct inputs and incorrect inputs? Do you have a 'make check' build command that confirms every test passes. Do you have a continuous-integration build system, where your system-level code is checked out of a code repository and is continually built and checked ... The complexity of real-world development occurs everywhere :) Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start ---
Any suggestion on how to handle this error? --- Quote End --- To the top of sopc_system_tb.sv add the line
`timescale 1ns / 1ps
Then Modelsim-ASE was happy for me. To build and run the code, on the Modelsim command line I used the commands;
do setup_sim.do
s
vlog -sv sopc_system_tb.sv
vsim -t ps -novopt +nowarnTFMPC sopc_system_tb
do sopc_system_tb.do
run -a
Enjoy! Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Many thanks again Dave. The timescale line fixed it. Yes you are right I have done only basic coding so far, nothing real world. One day perhaps... if I manage to survive all the FPGA learning. It's just that I've started learning about hardware programming around 4 months ago, but I feel that I spend most of my time learning how to use tools rather than actually doing anything productive. First it was Quartus, then SOPC, then NIOS SBT, now ModelSim.... But I guess it's the way to learn step by step.
Talking about learning, my current testbench in sv for my ST component doesn't do anything yet apart from just displaying a test message. I am trying to write an actual testbench with meaningful inputs.. be prepared for more beginner questions soon :)- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Yes you are right I have done only basic coding so far, nothing real world. One day perhaps... if I manage to survive all the FPGA learning. It's just that I've started learning about hardware programming around 4 months ago, but I feel that I spend most of my time learning how to use tools rather than actually doing anything productive. First it was Quartus, then SOPC, then NIOS SBT, now ModelSim.... But I guess it's the way to learn step by step. --- Quote End --- Trust me, it does not get any easier ... the tools change almost as fast as you learn them ... and then a new FPGA comes out and you have to start reading data sheets from-scratch again ... It does make for good job security though :) --- Quote Start --- Talking about learning, my current testbench in sv for my ST component doesn't do anything yet apart from just displaying a test message. I am trying to write an actual testbench with meaningful inputs.. be prepared for more beginner questions soon :) --- Quote End --- There are really two types of testbenches; interactive and automatic. An interactive testbench is one that exercises your design, but does not really check anything, eg., injects noise into a digital filter, writes the results to file, and then finishes. In this type of design, its up to you to check the results using say MATLAB to check the power spectrum. An automated testbench also checks the result, i.e., you have a "golden reference" output data file, and the testbench checks that the golden reference results were reproduced by the design. This last testbench is very useful as you don't need to look at the design once you've finished it, so long as you run the testbench, eg. using a makefile "make check" command. If you change a component that the design uses, and you break it, when you run the testbench it will fail, and you can go and fix the bug you just introduced. Keep that in mind while designing. Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Cheers Dave. I am doing the interactive testbench for now but I am having problems with reading the input data file. I have an array of size 153600 bytes that I save as follows in matlab:
fid = fopen('image_binval.bin', 'w');
fwrite(fid, data_image_1d,'uint8');
The main parts of my current systemverilog testbench file are shown below. I am just making sure the correct values are being read in. When I run it in modelsim, src_transaction.data shows the correct data values in the wavewindow until variable i reaches 57672. After that, it just displays a x in between red lines. I can't find where I am going wrong. Any help please?
`define NUMBER_OF_PIXEL_VALUES 153600
module sopc_system_tb();
// 50MHz clock period
localparam time CLK50_PERIOD = (1.0e9/50.0e6)*1ns;
// Clock and reset
logic clk;
logic rstN;
// Avalon ST
typedef logic AvalonSTData_t;
integer fileInput, r;
//the ST transaction is defined using SystemVerilog structure data type
typedef struct
{ int idles; //idle is not part of Avalon ST signal, it is used in BFM only
bit startofpacket;
bit endofpacket;
AvalonSTData_t data;
} transaction_struct;
transaction_struct src_transaction, snk_transaction;
int i, j;
// 50MHz system clock
initial
clk = 1'b0;
always
# (CLK50_PERIOD/2) clk <= ~clk;
// SOPC system -Set up the Dut
sopc_system
dut
.clk_0 (clk),
.reset_n (rstN)
// Stimulus
initial
begin
// Initialize input and output text files
fileInput = $fopen("image_binval.bin", "r");
r = $fread(storage_values, fileInput, 0, `NUMBER_OF_PIXEL_VALUES-1);
// Initialize the BFM
set_verbosity(`VERBOSITY);
`SRC.init();
`SNK.init();
rstN = 0;
# 50ns rstN <= 1;
$display("Simulation Start");
for (i = 0; i < `NUMBER_OF_PIXEL_VALUES; i++)
begin
@(posedge clk);
src_transaction.idles = 0;
src_transaction.data = storage_values;
if (i == 0)
src_transaction.startofpacket = 1;
else
src_transaction.startofpacket = 0;
if (i == `NUMBER_OF_PIXEL_VALUES-1)
src_transaction.endofpacket = 1;
else
src_transaction.endofpacket = 0;
end
end
endmodule
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- I am just making sure the correct values are being read in. When I run it in modelsim, src_transaction.data shows the correct data values in the wavewindow until variable i reaches 57672. After that, it just displays a x in between red lines. I can't find where I am going wrong. Any help please? --- Quote End --- I can't see anything obviously wrong. However, if you just want to check that data is being read in ok, change the loop to simply display the values read from the file, eg., something like
logic val;
for (int i = 0; i < `NUMBER_OF_PIXEL_VALUES; i++)
begin
@(posedge clk);
val = storage_values;
end
And display val in the wave window. Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- And display val in the wave window. --- Quote End --- Yeps, I've tried that but still the same result after the counter reaches 57672. Could it be that I have reached some kind of limit with my ModelSim Starter Edition? The Altera website says the limit is 10,000 executable lines. I don't have this number of lines, but the main top module does call a few IP modules such as altshift_taps.. so it could be the case :( Can somebody please confirm this? Assuming I get the data reading to work, I have a question related to Avalon ST this time: Is my implementation of endofpacket correct? if (i == `NUMBER_OF_PIXEL_VALUES-1) src_transaction.endofpacket = 1; I am not too sure if end of packet means the end of the whole of the data to be transferred. Also, how do I get output values from the device under test to go to snk_transaction.data?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Yeps, I've tried that but still the same result after the counter reaches 57672. Could it be that I have reached some kind of limit with my ModelSim Starter Edition? --- Quote End --- Post a .zip file with source and a simulation script, and I'll try it in SE. --- Quote Start --- Assuming I get the data reading to work, I have a question related to Avalon ST this time: Is my implementation of endofpacket correct? if (i == `NUMBER_OF_PIXEL_VALUES-1) src_transaction.endofpacket = 1; I am not too sure if end of packet means the end of the whole of the data to be transferred. --- Quote End --- You won't break anything in simulation, so your best bet is to just try the obvious and see what happens. I haven't tested ST interfaces with the verification suite, so cannot offer any experience. --- Quote Start --- Also, how do I get output values from the device under test to go to snk_transaction.data? --- Quote End --- I would look at the Avalon-ST example provided in the verification IP suite. Hopefully they show how to use the ST API and connect it to something. I think the main thing to keep in mind, is just to try stuff, look at the waveform view, and try and clear up anything that is red. The other thing to do is look at the source code for the verification functions. Cheers, Dave
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for your continuous support Dave. I don't think this problem is related to ASE, because I have just installed the full edition (I didn't even know we had this license!) and I still face the same problem. The error is happening with the $fread command. For example, in the following line, read_index stays at 57671 when I look at the waveform window. It's expected to be NUMBER_OF_PIXEL_VALUES-1 instead.
read_index = $fread(storage_values, fileInput, 0, `NUMBER_OF_PIXEL_VALUES-1);
I then tried to use $readmemb but not much luck with this either... it sent modelsim crashing when I tried to simulate it! I'm attaching the zip file which contains the simulation script(sopc_system_tb.sv) and the input data file(image_binval.bin) in folder sopc_system_sim. Could you have a go at reading the data file please? It contains 153,600 values of unsigned 8-bit integers.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hmmm.. just forget my previous message concerning $fread. I managed to get it working by adding a "rb" instead of "r" in $fopen. Dow!! I feel so stupid :)
fileInput = $fopen("image_binval.bin", "rb"); OK, I'll start reading the Avalon ST documentation now and try things.. real work starts! Hopefully somebody with experience of ST verification will turn up on that forum soon too.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Hmmm.. just forget my previous message concerning $fread. I managed to get it working by adding a "rb" instead of "r" in $fopen. Dow!! I feel so stupid :) --- Quote End --- Don't feel too bad. That's part of learning a new tool. If everything worked the first time, you'd never learn how to debug. Cheers, Dave
