21594 Discussions
EK-10M08E144 PCB .brd file corrupted
Ed1632
1 106 Visites
I am working on a layout for a MAX10 (10M08SA2884 EQFP144) to implement our firmware design created on the EK-10M08E144 development board. I downloaded the dev board document installation (from https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/max/10m08-evaluation-kit.html ) but I cannot open the .brd file.
The Altium importer refuses to import them, suggesting conversion to Modern Eagle v6 XML format, but Eagle will not not open the .brd file ( "Error: line 1, column 1: Start tag expected.")
Is there a reference hardware design or updated dev board layout I can use as a reference for my design, preferably compatible with (or importable to) Altium 24?
Thank you in advance,
Ed
Étiquettes (1)
0 Compliments
7 Réponses
FvM
Contributeur émérite II
1 075 Visites
Wrong thread title. Not corrupted, just wrong layout tool used. It's Cadence Allegro.
Ed1632
1 069 Visites
Aha- thank you for catching that. The Altium importer still doesn't like it- "importing files in Binary format requires Cadence Allegro on system... If Cadence Allegro is not available, please use the ASCII(*ALG) file format instead."
I tried opening in it in the Allegro free viewer and and got "ERROR(SPP_HDB181): The  current version of software is unable to open design ... The design was last saved using version 16.5 and must be updated using DB Doctor."
I will hunt around for an Allegro installation (or DB Doctor, whatever that might be); in the meantime, is the EK-10M08E144 layout available in any other file types or versions? I would love to have this as a reference; nobody wants to do another board spin because I messed up a detail.
0 Compliments
Ed1632
1 069 Visites
(As for the title, you are right  it is probably not corrupted, but I am not having any luck changing the thread title)
0 Compliments
NurAiman_M_Intel
Employé
924 Visites
We only provide the PCB file the same format that you can get from the devkit page.
Aiman
Ed1632
902 Visites
OK, thank you Aiman. Be aware that your board file is out of date and not accessible to recent Allegro viewer releases- please consider updating your support files.
I have found a Cadence 16.5 installation but have not been able to open the .brd file yet- I think there are still some PC/license issues at play. Thanks for your help.
Ed
0 Compliments
NurAiman_M_Intel
Employé
855 Visites
Thanks for your update. Will let the team aware of this.
Aiman
0 Compliments
NurAiman_M_Intel
Employé
855 Visites
 I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
0 Compliments
Répondre
