21615 Discussions
ELF downloaded but switchers don't respond !!!
hello
I am working on niosII 13.0 web edition trying to command 2 LEDs using 2 Switchers on Cyclone III board
the niosII console shows that the elf is downloaded BUT when i click on Sw nothing happens !!
what could be the problem ?!
Downloading 00004000 ( 0%)Downloading 00004F0C (61%)Downloaded 4KB in 0.0s Verifying 00004000 ( 0%)Verifying 00004F0C (61%)Verified OK Starting processor at address 0x00004020
#include "io.h"
# include "system.h"
* Gets led_pattern as parameter in order to write to the register.
void set_led(unsigned char led_pattern) {
IOWR(LED_BASE, 0, led_pattern); // writes register
* Main, what else?
* Gets LEDs pattern from switchers.
* Sets LEDs register according to the pattern.
void main() {
unsigned char led_pattern = 0x00;
while (1) { // infinite loop
led_pattern = IORD(SWITCHER_BASE, 0); // gets LEDs
set_led(led_pattern); // sets LEDs
