21615 Discussions
EP3C120 developement kit Critical warning
I'm trying to compile with EP3C120 developement kit board... I have
some criticals warning
--- Quote Start ---
Critical Warning: Pin ddr2_dqs[0] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[0] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[1] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[2] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[3] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[4] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[5] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[6] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[7] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dm[0] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dqs[1] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[10] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[11] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[12] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[13] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[14] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[15] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[8] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dq[9] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_dm[1] must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_ck_p must have its Current Strength logic option set to 12mA, instead of Default
Critical Warning: Pin ddr2_ck_n must have its Current Strength logic option set to 12mA, instead of Default
--- Quote End ---
i have erros "can't fit" when i set value to 12mA
Any ideas? Thanks.
You should mention the explaining text with error message "can't fit" and the Quartus version. Also, did you include all I/O settings (tcl-files) generated by the Megawizard?
Yes include all tcl files...
Quartus version 8.1
error message :
--- Quote Start ---
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[0]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[1]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[2]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[3]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[4]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[5]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[6]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[7]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[8]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[9]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[10]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[11]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[12]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[13]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[14]", but setting is not allowed with a Termination assignment
Error: Current Strength logic option is set to 12mA for pin "ddr2_dq[15]", but setting is not allowed with a Termination assignment
Info: Fitter preparation operations ending: elapsed time is 00:00:03
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 17 errors, 4 warnings
Error: Peak virtual memory: 253 megabytes
Error: Processing ended: Tue May 05 14:23:19 2009
Error: Elapsed time: 00:00:13
Error: Total CPU time (on all processors): 00:00:10
Error: Quartus II Full Compilation was unsuccessful. 19 errors, 367 warnings
--- Quote End ---
Thanks for help
O.K., so you are using a 50 or 25 ohm termination setting for the pins. Only one IO-strength setting can be active at a time, termination isn't but a different form of current strength setting. The above warning should be regarded as a Quartus bug in this case and can be ignored. You may want to check in the fitter report, that the intended setting have been actually applied. And report the apparent bug to Altera support.
Thanks for you help :)
