Programmable Devices
21611 Discussions
EP3C16F256 Configuration
I have my configuration running on a DE0 board but I planned on using the EP3C16F256 in the actual application.
I am confused on how to configure the EP3C16F256, does it not support AS configuring with an EPCSx device?
Chapter 9 of the handbook seems to indicate so.
Rich
which portion of the doc are you referring to? note that Table 9-10 applies to AP not AS configuration
the mention device should support AS
--- Quote Start ---
--- Quote End ---
this is what I found confusing, from chapter 9:
Smaller Cyclone III devices or package options (E144, M164, Q240, F256, and U256
packages) do not have the MSEL[3] pin. The AS Fast POR configuration scheme at 3.0-
or 2.5-V configuration voltage standard and the AP configuration scheme are not
supported in Cyclone III devices without the MSEL[3] pin. To configure these devices
with other supported configuration schemes, select the MSEL[2..0] pins according to
the MSEL settings in Table 9–7.
Perhaps this means that the AS fast POR at 3-2.5V is not supported but it is at 3.3V???
So there is no MSEL[3] pin but all the configurations show it used....
Rich
right, without MSEL[3] you can do AS with standard POR at 3.3V or 2.5/3.0V or AS with fast POR only at 2.5/3.0V (but not at 3.3V). that's shown in Table 9-7
--- Quote Start ---
--- Quote End ---
OK, I guess I have have all options where MSEL[3] is low (0)?
Rich
yes, i guess the documentation doesn't really spell that out
--- Quote Start ---
--- Quote End ---
hey, thank you very much for the help!
Rich
