I have my configuration running on a DE0 board but I planned on using the EP3C16F256 in the actual application. I am confused on how to configure the EP3C16F256, does it not support AS configuring with an EPCSx device? Chapter 9 of the handbook seems to indicate so. Thanks RichLink Copied
which portion of the doc are you referring to? note that Table 9-10 applies to AP not AS configuration
the mention device should support AS- Mark as New
--- Quote Start --- which portion of the doc are you referring to? note that Table 9-10 applies to AP not AS configuration the mention device should support AS --- Quote End --- this is what I found confusing, from chapter 9: Smaller Cyclone III devices or package options (E144, M164, Q240, F256, and U256 packages) do not have the MSEL[3] pin. The AS Fast POR configuration scheme at 3.0- or 2.5-V configuration voltage standard and the AP configuration scheme are not supported in Cyclone III devices without the MSEL[3] pin. To configure these devices with other supported configuration schemes, select the MSEL[2..0] pins according to the MSEL settings in Table 9–7. Perhaps this means that the AS fast POR at 3-2.5V is not supported but it is at 3.3V??? So there is no MSEL[3] pin but all the configurations show it used.... Thanks Rich
right, without MSEL[3] you can do AS with standard POR at 3.3V or 2.5/3.0V or AS with fast POR only at 2.5/3.0V (but not at 3.3V). that's shown in Table 9-7
--- Quote Start --- right, without MSEL[3] you can do AS with standard POR at 3.3V or 2.5/3.0V or AS with fast POR only at 2.5/3.0V (but not at 3.3V). that's shown in Table 9-7 --- Quote End --- OK, I guess I have have all options where MSEL[3] is low (0)? Thanks Rich
yes, i guess the documentation doesn't really spell that out
--- Quote Start --- yes, i guess the documentation doesn't really spell that out --- Quote End --- hey, thank you very much for the help! Rich
