Programmable Devices
20738 Discussions
EP4CE6F17C8N
Lida8
Dear Support,
I have a question for EP4CE6F17C8N,Kindly help to check and confirm.
There are two date codes 2043 & 2113
Please refer to attached photo.
Two layers of marks can be seen on the side of the body. Please tell me if this is normal?
AqidAyman_Intel
By say two layers of mark, did you mean the one that indicates in the red box?
Aqid Ayman
Lida8
yes
AqidAyman_Intel
Can you confirm to me, which date code have the marks on the side of the body? Is it both devices?
Another one, could you give me lot number (second row from bottom) for both devices in order for us to proceed with the checking? The picture you give was unclear for the lot number written on the packaging.
Aqid
Lida8
HI,Regards
Both devices are marked
Sample 1  Lot:S042AK5F  Date:2043  COO:KR
Sample 2  Lot:S115AF10  Date:2113   COO:KR
Lida8
HI,Regards
AqidAyman_Intel
Thank you for the clarification on the lot number. However, the lot number for Sample 1 is not exist in Intel system as per checked. Could you confirm back to me on your company's name as for us to check on the shipment history?
In addition, if you purchased Sample 1 and Sample 2 from distributor, could you provide me the distributor's name?
Thank you.
Lida8
You mean sample 2 can be found in your intel system, right?
AqidAyman_Intel
Hi Shu,
Just got updated, sample 2 lot number is a valid lot number. However, when we checking the details through our system, it is shown for different device family and packages. It is also a wrong lot number for the part you shown to me in the pictures.
Lida8
AqidAyman_Intel
Hi Shu,
I could not confirmed on that. Could you provide me the distributor's name where you purchased it so that we can check with the shipment history?
Aqid
AqidAyman_Intel
Just want to ask for the update on my last question to you. If you are not giving the information needed, it is difficult for us to offer a further support regarding this issue.
Aqid Ayman
