21615 Discussions
EPCS read problem
Hello All,
I have a problem with a access to the EPCS .
I have a NIOS design with epcs controller. My SW use the altera_avalon_epcs_flash_controller. My HW is a “NiosII Development Board Cyclon (1C20)” and a “NiosII Development Board CyclonII (2C35)”.
My design SW is QuartusII 9.0 and 9.1.
1) I load the design with JTAG to the HW I can read an write from/to the EPCS
2) I program this design to EPCS and load from this I can read and write from/to the EPCS
3) I program this design to parallel FLASH and load from this I can NOT read the EPCS. The access to EPCS is not possible. The return value of alt_epcs_flash_init is -19 the return value is -22 if OK. The EPCS is unrealized.
This problem is with both Quartus versions and both EVA boards.
Why cannot read EPCS if design is load from parallel Flash?
Kind regards
weibu
There was an issue when both CFI and EPCS were present and included in SOPC, but that was a couple of years ago Quartus 6
There was a "workaround" as we had used both at the same time, fpga image from cfi and EPCS available for access to store another image + SW + user data
I have not understood this completely. What I must do with it I can read from the EPCS.
weibu
